| | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | my folks just bought 54 acres that used to belong to a trashy contractor and the land is covered in metal from nails, ps pumps, rims and I even found an old rifle that went throught a fire. you get the idea. I need a magnet to pick up small stuff and was thinking of something like 60" to 72" across to hang from the bucket of my tractor. what do you guys reccomend? this is what I found so far http://www.northerntool.com/shop/tools/product_25122_25122 | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Do they rate it for pounds lifting capacity ie will it pick up rifles, old crankshafts, etc etc.
Saw a few used but seemed like the challenge was getting the junk off it when done.
Dan Bentler | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Hi Tyler,Check at harbor freight,they have some pretty big ones for construction sites,nail control.We have one on wheels at work.We just roll it around like a pushbroom.They also sell the metal detector wands, like at the airports, | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | thanks Marty, I forgot about HF I remember them selling the push type but I'll check and see if they have anything bigger. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think you will have to use an electro magnet. A magnet strong enough to pick up big stuff will be hard to remove the stuff because it will be really stuck. We have a magnet that roofers use to pick up roofing nails hanging on the back of our all terrain forklift to pick up stuff in our truck yard to prevent flats. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | I would recommend some sort of electromagnet setup. Here is a link to some ideas on how to make it work. I bet you could make a electromagnet the width of the bucket, insulate some hooks and hang it off the front of the bucket. wire it up to your tractor battery and put a switch in the line. turn it on, pick up junk, then head to a scrap pile, turn it off, and voila, recyclers' dreams.
the other thing that works really well for cheap strong magnets are speakers. If you can find some that have been junked (may try a car stereo place). I bought 4 6x9 speakers at a garage sale and took the speaker part off. Each magnet had a hole through the center and I just bolted them onto a bar. I put the bar on a pair of lawnmower wheels and push it around when I need to clean up. wrap a shop rag or old tshirt around the magnets to aid in removal of the retrieved items.
| | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | the electromagnets sounds like the way to go and if I could make my own that would be great. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Tyler, Carl and I would drag old speakers around Ed's yard,youd be surprised at what they would pick up. | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | thanks guys, I'll try making making one 72" across with old speakers and see how it works. should I use a 2"-4" or I have some aluminium channel I could use. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | Don't forget to wrap them with an old rag, or something else, for easy removal of material picked up. | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | will do. I'll post some pics when I finish making it. | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | I know what worked well for me, driving my tractor with the new six foot snowblower into the pasture and picking up that logging chain I forgot was out there. Worked great, but pretty sure I can't do it again!
| | | | | Joined: Aug 2006 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 30 | I use 12V magnet coils from automotive air conditioner compressors. I have a toggle switch in line to drop the debris. I would suppose you could mount several of them along a loader bucket.
"Nothing is ever as simple as just turning wrenches!"
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Why would anyone go to Harbor Freight looking for something useful? | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Why would anyone go to Harbor Freight looking for something useful?I did buy a package of sandpaper there one time that actually worked out pretty good.But most of their stuff is pure junk. | | |
