5 members (Brian Moore, texas46, dt235sd, TexasA&M48Truck, Steelonsteel), 59 guests, and 1 robot.
Topics128,022
Posts1,055,381
Members48,422
#691329 11/02/2010 7:02 PM
Will a Rochester B Carb work on a 292 ?
That's the carb that came on the early 292's before they came out with the mono-jet.
The 292 carb has a larger throttle bore than a 250 or 230.
Steve
'49 3800
'52 3600
'57 3100
However: IIRC the original 1963-66 B didn't have a PCV. If you have one, get a 1967.
I have a monojet on it now,should I leave it on ? How does a pcv hook up yo a carb ?
gmguy #691713 11/03/2010 11:41 PM
Riding in the Passing Lane
The PCV hose hooks to a tube in the intake masnifold on the 3-4 intake runner. Either carb will work if the linkage & fuel line are hooked up. The 292 comes with a larger bore but often it has been replaced with a 230-250 carb. The rebuilders just mix them up.
1972 Chevy c10 Cheyenne Super
