| | | Forums66 Topics128,026 Posts1,055,402 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 35 New Guy | | New Guy Joined: Sep 2009 Posts: 35 | Will a Rochester B Carb work on a 292 ? | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | That's the carb that came on the early 292's before they came out with the mono-jet. The 292 carb has a larger throttle bore than a 250 or 230.
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | However: IIRC the original 1963-66 B didn't have a PCV. If you have one, get a 1967. | | | | | Joined: Sep 2009 Posts: 35 New Guy | | New Guy Joined: Sep 2009 Posts: 35 | I have a monojet on it now,should I leave it on ? How does a pcv hook up yo a carb ? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The PCV hose hooks to a tube in the intake masnifold on the 3-4 intake runner. Either carb will work if the linkage & fuel line are hooked up. The 292 comes with a larger bore but often it has been replaced with a 230-250 carb. The rebuilders just mix them up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
