3 members (IHPWR, Otto Skorzeny, WICruiser), 85 guests, and 1 robot.
Topics128,029
Posts1,055,417
Members48,422
I've tried using brake cleaner with fine steel wool but can't get all the surface rust off the brake surface of the drum. Is there something better to use or should I have a shop lightly turn it?
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
It would depend on what is classified as surface rust and how new the linings are but I would normally just drive slowly and ride the brake a bit ( helps break in new linings anyways) and they will look brand new after about half a mile or more. turning them just to remove rust will reduce your drums expected life because they will turn a thou or two out just to clean them and is normally cost prohibative.
Ex Hall Monitor
Ex Hall Monitor
Yep, just drive it.
If there's no big, heavy flakes of rust, just drive it. If you want to remove most of the rust first, use 100-grit body sanding paper, and scrub it vigorously. Yuu're not going to hurt the drum, or remove enough metal to matter. We use 100 grit paper to scuff-sand disc brake rotors after machining to get a "non-directional" finish that increases pad life.
Thanks guys, appreciate the advice!
Allan
1951 GMC 1/2-ton
