4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I've tried using brake cleaner with fine steel wool but can't get all the surface rust off the brake surface of the drum. Is there something better to use or should I have a shop lightly turn it?
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Jul 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 56 | It would depend on what is classified as surface rust and how new the linings are but I would normally just drive slowly and ride the brake a bit ( helps break in new linings anyways) and they will look brand new after about half a mile or more. turning them just to remove rust will reduce your drums expected life because they will turn a thou or two out just to clean them and is normally cost prohibative. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | If there's no big, heavy flakes of rust, just drive it. If you want to remove most of the rust first, use 100-grit body sanding paper, and scrub it vigorously. Yuu're not going to hurt the drum, or remove enough metal to matter. We use 100 grit paper to scuff-sand disc brake rotors after machining to get a "non-directional" finish that increases pad life. Jerry
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Thanks guys, appreciate the advice!
