4 members (tclederman, Shaffer's1950, treegrower, Buckeye998), 337 guests, and 2 robots.
Topics128,152
Posts1,057,012
Members48,460
Apart from the VIN, how would you tell a 1.5 ton from a 2 ton? I am looking at a nice big bolt, suppose to be a 1946 1.5 ton. I measured the wheelbase: 160. That could be either 1.5 or 2 ton. The VIN plate says: 50F 05 2698. I looked at the VIN/Model guide on Whitney's site at http://www.haist-usa.com/artdecotrucks/identification.htm
The "5" means made in Kansas City. The next two letters would have to be the Model. I have 0 (the number) and F, but it could easily be O (the letter) and F, which would mean it's a 2-ton according to the guide. However, the seller has the title and it is represented as a 1.5 ton. Any other way to be sure? Here's a pic: http://www.alignment2012.com/1946ChevyTruck5.JPG
Can you post another pic that one was fuzzy.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
The best resolution pic I have of it is here:
http://www.alignment2012.com/1946Chevy.jpg
Johnnyc47
Unregistered
Johnnyc47
Unregistered
Either way its a cool truck!
it is a 1946 chevy 2 ton if the title says 1.5 see if the numbers match if so most people dont know the diffrence if thay match go to brads 46 site in the links print out the vin chart and ask dmv to fix it
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
If the wheels are any indication, being 7 holes, and they haven't been changed out, they tell me that this is a 1.5 ton, of coarse, I'm not completely in the know about the earlier design series, so, I may be way off base here.
Jeff
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Jeff
The rims on a 41-46 chevy 1.5 ton actually has 5 hand holes, not 7. I had to search through alot of info on the wheels for this model, I needed 1 more for my 41 1.5 ton. I think that the larger GMCs had wheels like yours, but I don't know much about the 2 ton chevs, I thought they would be the same as the 1.5 ton. What size are you tires?
Tires are 7.50 x 20 Dunlops.
Wheel hand holes, not a indicator on truck size. My '46 2 ton had 5 hand hole wheels. Wheels are changed numerous times throughout a trucks life. "OF" in the ID number, indicates it as a 2 ton. A 1946 1 1/2 ton would be "OS".
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
And, there you have it. wave From a man that knows more about this than me. headscratch Good job Spanky thumbs_up
1953 Chevy Two-Ton
