4 members (jay d, Youngin' Tut 59, TooMany2count, 1 invisible), 83 guests, and 2 robots.
Topics128,139
Posts1,056,754
Members48,454
Hi,
I got a guide 6004 turn signal unit from epay and would like to install it in my '51 1/2 ton truck...problem is, I can't find a realible wiring diagram. Anyone has one I can use. The one I found on "tech tips" shows a 2 prong flasher and I was told a needed a 3 prong.
The 6004 unit appears to have 7 wires, am I wrong?
Greatly appreciate any help.
need to look at that tip again and read the whole thing
I just need to make sure of one thing for those that can help me. I have one wire left to connect but I am a bit confuse...the wire going from the turn signal switch to the stop light switch...which side of the stop light switch do I coonect it to, the one connecting the wire coming from the stop light (I think this is it) ot the one coming from the headlight switch?
Thank you, I am almost done
it hooks to the side that goes to the lights
Thank you Bill. This is my first ever electircal work and I wanted to make sure I am doing it right.
thumbs_up
