| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69083 11/24/2006 10:22 AM | Joined: Nov 2006 Posts: 25 Junior Member | | Junior Member Joined: Nov 2006 Posts: 25 | Would I be able to use parts from a 250 such as harmonic balancer, water pump, dist., intake and exhaust manifolds and use them on a 292. Thanks. | | |
#69084 11/24/2006 4:48 PM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I wouldn't use the Harmonic balancer, water pump, thermostat housing, and the side covers won't fit. Everything else should be good. The water pump has an additional outlet that feeds the thermostat housing, this might of changed on later engines. The harmonic alancer isn't big enough.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
#69085 11/24/2006 5:18 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | no, many are different see http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011811#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011086#000000
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#69086 11/24/2006 10:53 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The manifolds & dist. will fit. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#69087 11/25/2006 4:19 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | carolines truck, In your first link it was never determined what manifold wouldn't fit. The manifold was suppose to be a 250. There are some differences in exhaust manifold, but none of differences should keep the manifold from bolting to either a 250 or 292.
The second link refers to internal engine parts and yes there are a lot of differences. Freds has limited the parts to external.
Fres, did forget to mention motor mount towers. The mounts are the same, but were they bolt on is different. You will need to give us some more details before we know if that is a problem.
Larry
