1 members (baldeagle),
34
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 20 New Guy | | New Guy Joined: Feb 2008 Posts: 20 | Well it's time to paint the frame on my 1948 GMC 1/2 ton Panel. Truck will look stock but running gear is not. Truck came from factory Green and will stay Green. I,m thing about using a satan black on frame and engine compartment minus firewall. is there a better choice ? Thanks Dave | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Sounds good to me even though I pained my frame gloss black.
I used Rustolium Satin Black for some things like inner fenders and it looks real good. I also used Rustolium Gloss Black for the frame but if I had it to do over, I'd use a 2K Urethane. It's thicker and harder... I've used it for my running boards, pedal rods and some other odds and it looks super.
Not sure if you can get satin black (AKA Underhood Black) in 2K but I'd look into it if I were you. | | | | | Joined: Feb 2008 Posts: 20 New Guy | | New Guy Joined: Feb 2008 Posts: 20 | Thanks for the imput. I keep thing about going with a gloss black, but I,d send what little time I don't have trying to keep it nice and shiney. and that the only reason for using satan black. I,ll try to find a two part for the hardness. Thanks Dave | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | I used rustolium Satin on the wishbones of my model A - the wishbone is directly under the carb wich always leaks and have not seen any wear issues with the paint.
....David
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Originally I used EASTWOOD Chassis Black diluted per directions to apply with a commercial gun. But,they have it in aerosol cans too. They also have newer, better choices now too. It's more expensive than your local hardware store, but it relly covered well and has held up very well. It also touches up easily when needed.
Drew
