2 members (klhansen, 2-Ton),
85
Mod | | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 46 | Does any one know the towing capcity of a 47-53 chevrolet truck 1 ton gross weight of 8800 lbs is? It has a 5.14 rear end and a newer 56 full pressure 235 CI engine and the 4 speed? This is saying I have the right class of tow hitch lights etc. I do have all stock drum brakes all around with a new power booster. Any one know the answer, thanks Gerry | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I may be wrong but I don't think they gave a tow rating for it in those days. I would think that should at least be able to tow your payload, with trailer brakes of course. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Trucks didn't get a gross combination weight rating under 2 ton or maybe 1 1/2 ton. The towing capacity all depends on how fast you want to go and how well you can stop. | | |
