Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (cmayna, EddieD, 2 invisible), 47 guests, and 3 robots.
Topics128,009
Posts1,055,291
Members48,419
#689641 10/27/2010 6:09 PM
I just replaced my front springs on my '53 3600 and the shop manual just says to "tighten the U bolt nuts "securely". What is the proper torque spec and is there a torque spec page that covers many parts on the truck?
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
John Hill #689656 10/27/2010 6:38 PM
From a '48-'51 shop manual:
Spring "U" Bolt Nuts
3/4, 1, 1 1/2, and 2 Ton 125 - 150 ft. lbs.
1/2 Ton 75 - 90 ft. lbs.
http://chevy.oldcarmanualproject.com/chevyresto/53131.htm
The U-Bolt diameter, 9/16" is the same for your '53 as '51, so torque spec should be the same.
Drew
DrewP #689667 10/27/2010 7:03 PM
Drew,
I opened your link but see only the U bolt diameter but not the torque specs. Is that found elsewhere?
John Hill #689668 10/27/2010 7:16 PM
Try this link
waldo53 #689692 10/27/2010 9:36 PM
Thanks.
I have a somewhat related question about the U bolts. I bought mine from LMC and they came with heavy flat washers. The old ones that I removed also had flat washers. The shop manual says to install the U bolts and "lock" washers. Does anyone know for sure which type of washer is appropriate?
John Hill #689724 10/27/2010 11:58 PM
I'd use what you have. Put a little lock tite on 'em and torque 'em to spec.
I am a bit of a redneck though... grin
John Hill #689727 10/28/2010 12:05 AM
I've only seen the heavy flat washers used there. The nuts should be the "tall" (if that's the right word) type.
waldo53 #689735 10/28/2010 12:31 AM
I'll leave the heavy flat washers and I do have the "tall" 3/4" head nuts. I have torqued them 75 ft/lbs.
Thanks as always for the help.
John Hill #689748 10/28/2010 1:25 AM
That is the torque listed for the 3100 above. Did you say yours is a 3600?
1951 1 Ton Completed
truckernix #689940 10/28/2010 6:30 PM
C Online: Content
Whenever you can't easily find the torque specs for any bolt in your shop manual, here's a very good torque spec sheet that cover all bolts and grades. Don't over torque!!!
Torque spec chart
Craig
cmayna #689948 10/28/2010 6:55 PM
truckernix,
Mine is a 3600 but had 1/2" U bolts on it and that is what was supplied by TMC. The holes in the axle are drilled for 1/2' not 9/16. Unless the entire front axle was replaced, I can't explain why my 3600 had 1/2" U bolts. Under any conditions, all that the U bolts do is hold the springs down onto the axle. The weight of the truck and load pushes the springs down on top of the axle. No extra weight is placed on the U bolts. They just hold the parts together and I will not carry heavy loads.
Cmayna,
Thansk for the torgue link.
John Hill #690173 10/29/2010 2:29 PM
U-Bolt Tip:
Anyone that wants to replace any size U-Bolt on their truck should consider shopping at their local recreational trailer dealership or repair shop. They'll have all sizes and likely cheaper then the aftermarket retailers.
Drew
DrewP #690652 10/31/2010 6:12 AM
Originally Posted by DrewP
U-Bolt Tip:
This is very good advice.
