2 members (Shaffer's1950, 1 invisible), 36 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#690561 10/30/2010 11:16 PM
Does any one know the towing capcity of a 47-53 chevrolet truck 1 ton gross weight of 8800 lbs is? It has a 5.14 rear end and a newer 56 full pressure 235 CI engine and the 4 speed? This is saying I have the right class of tow hitch lights etc. I do have all stock drum brakes all around with a new power booster. Any one know the answer, thanks Gerry
1953 1-Ton Canadian Model 1434
More pix on Photobucket
I may be wrong but I don't think they gave a tow rating for it in those days. I would think that should at least be able to tow your payload, with trailer brakes of course.
1951 1 Ton Completed
Trucks didn't get a gross combination weight rating under 2 ton or maybe 1 1/2 ton. The towing capacity all depends on how fast you want to go and how well you can stop.
