3 members (walter74, Guitplayer, Greg_H), 106 guests, and 1 robot.
Topics128,055
Posts1,055,785
#688173 10/21/2010 10:30 PM
jmh
Offline
Hi all,
My old 216 finally bought the farm(she blew up). I am going to swap it out for a mid seventies 250. Any ideas on short cuts or problem areas. It is going in a 1948 2 ton.
JMH
jmh #688186 10/21/2010 11:39 PM
Hi JMH Im tring to do the same thing in a 52. Someone have any info. Thanks Bob
retired5150 #688203 10/22/2010 12:31 AM
There is a good tech tip on this site about the bell housing you will need for the swap. You can also search these forums as this swap has been discussed, and done a lot. Good luck!!
Professional Novice
retired5150 #688210 10/22/2010 12:39 AM
Y
Y Offline
Probably no shortcuts, obviously you'll need custom motor mounts. The early V8 bell housing works on a 54 crossmember. Water pump/fan will be tight fit but will work, and be a little low on the radiator. Someone makes custom motor mounts, do a search, topic has been well covered. I'm putting a 250 in my 54 3100.
Yakimabowtie #690573 10/31/2010 12:17 AM
jmh
Offline
Thanks everyone. The swap is forthcoming. I think I have the details worked out. See my latest post in the Big Bolts forum.
Thanks JMH
