| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I have a 235 with a 12 volt generator, 6 volt starter, stock distributor and a coil that has no indication that it has an internal resistor.
How do I wire the ballast resistor? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you want one end of the resistor to get power from the ignition switch when "on" and the other end to the coil +
then if the starter has a terminal from the side of the foot switch on top, a wire from there to the output side of the resistor [so "bypassing" it] or direct to the coil + [again, bypassing the resistor] .... if the starter doesn't have that side terminal you can skip it or rig another way to have full 12V to the coil when the starter is engaged - or get an internally resisted coil is easiest
the object is to give the coil the extra juice to insure good spark when the starter is drawing a lot, but that won't be as much of a problem as not having the resistor in the circuit and feeding too much during normal operation
Bill | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Thanks Bill, that answers my question! | | |
