1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 19 New Guy | | New Guy Joined: Sep 2009 Posts: 19 | Hello, I'm looking at a '54 3600 pickup, it advartised as a 3/4 ton, but its a dually... I looked around here and on the interned in general, and didn't find anything about the 3/4 ton comming as a dually. Is that original? Also, there is no bed, was there a dually truck bed with fenders or did they only do duallys as a flat bed?
Thanks, Jason | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There was a dual wheel option on 3/4 ton at least up to the late '60s. The dual wheel trucks would not have come with a pickup bed.
Bill Burmeister | | | | | Joined: Sep 2009 Posts: 19 New Guy | | New Guy Joined: Sep 2009 Posts: 19 | Thanks for the info, is there a bed that will fit, or fenders that will work aftermarket or otherwise? I like the dually look but would really like normal truck bed. The flat bed is more farm truck looking than what I'm going for.
Thanks, Jason | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I beleive there are wider stepside fenders available, if you don't mind using fiberglas. You'll have to make your own running boards, though, as I thing the tapered boards they make to go with the fenders are for 1/2 ton only.
Bill Burmeister | | | | | Joined: Sep 2009 Posts: 19 New Guy | | New Guy Joined: Sep 2009 Posts: 19 | Thanks for the info, I'm waiting to hear back from the guy to get more info on the truck.
Jason | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Hello, I'm looking at a '54 3600 pickup, it advartised as a 3/4 ton, but its a dually... Duals became an option on 3/4-ton trucks starting in '54. Check the serial number and wheelbase to determine what it really is. Resto Pack for '54 3600
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2007 Posts: 44 New Guy | | New Guy Joined: Dec 2007 Posts: 44 | I have one of these rides better than my 55 1st series pickup. I have the grain box mine could be why it rides better with all the weight. Great trucks | | |
