2 members (Hotrod Lincoln, 1 invisible),
156
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | F10J9E47425
This is supposed to be a '59, 1/2 ton chevy pickup but the online VIN decoders I've tried come up blank. The format doesn't match the guide in the LMC catalog. Can anyone decyper this or point me to a source that can do it. Thanks.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you're right, it doesn't compute - might be an engine number but it's not a factory 59 vin, they start with a number/letter combination the indicates the model/series, the 1/2T would be 3A [short] or 3B [long]
Bill | | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | I'm not one of the numbers gurus, but that's a tough one.
Where did the number come from? Paperwork? Door Post? Frame? I know the TF trucks drop the leading "3A" (series and model) from the frame stamp.
Still, to only have five digits at the end of your VIN eliminates a lot of things... like any Chevy truck VIN after 1953. Also don't think it is an engine serial. Throw in the random letter placement - well, it's beyond my feeble abilities.
1956 Chevy 3600 Dually
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | It's supposedly on the title for a '59 chevy pickup. I haven't seen the truck or the title yet. Just doing a little research.
| | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | Ah, I see - you're buying a title on eBay. Good luck.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | How about getting us a picture of the number you need decoded. | | |
