| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | In ’41 the ¾ ton had a unique drive system. The transmission (a crash box) remained the older torque tube (enclosed drive shaft) type. The drive shaft is a two piece unit with the front section being an enclosed unit and the rear being open.
I have just replaced the center (hanger) bearing. When reading the instructions in the manual I discovered that the enclosed drive shaft section is supposed to be filled with a pint of gear lube.
Is this the same for the full length unit on half tons??
