| | | Forums66 Topics128,094 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | I found a 94 2WD Chevy 3500 Dually that is being parted out. Is it possible for the control arms out to mount directly onto my 64 dually? would the spindles work? It would be really nice to have discs on this monster of a truck. Anyone know? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. The suspension on the '88-'98 GMT 400 trucks is a very different design, nothing interchanges. What you need to look for is the '73-'86 C-30/'87-'91 R30/3500 trucks. Those will have the spindles that can be swapped. You would use the original control arms, but the balljoints and at least the outer tie rod ends will have to changed to the later style.
Bill Burmeister | | |
