2 members (Bill Hanlon, Lightholder's Dad), 118 guests, and 1 robot.
Topics128,131
Posts1,056,724
Members48,454
#6892 10/13/2002 3:15 AM
I have an unusual question for all of you.
Does anyone know what weight oil goes into the oil bath air cleaner for a single barrel rochester carb?
also I was wondering has anyone ever opened up the oil bath air cleaner and modified it to hold a modern air filter. I thought this would make for less of a mess, and still look original.
I had logged a question a while back about getting to much gas and not enough air into the carb, well it turned out I was using to heavy of a weight of motor oil in the breather. I switched to an after market filter, but would like to find a way to use the original parts. Thanks for any help you can supply. smile
56 stepside 3/4 ton longbed
#6893 10/13/2002 3:48 AM
Prior to the 60's when John Deere used oil baths, they recommended using the same weight oil you were using in the engine. From what I have read this is also GM's recommendation.
With a little patience and time I would think you could modify a stock air cleaner to accept a paper filter--some vendors offer one for John Deere two cylinder restored tractors.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#6894 10/13/2002 4:43 AM
An old mechanic told me to use 30 wt. thined with a little diesel.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#6895 10/13/2002 1:38 PM
If you look in the Cars and Parts issue just coming out, that would be Nov 2002, the Toolbag column has quite a few descriptions of how people modified their oilbath aircleaners to take a paper element.
1951 1 Ton Completed
#6896 10/13/2002 7:55 PM
The 1954 truck owners manual says ". . S.A.E. 50 weight in summer and lighter in the winter".
Tim
#6897 10/13/2002 8:14 PM
I'm in Texas, use 30w year round never a problem.
Buzz'n Half Dozen
#6898 10/13/2002 11:25 PM
Junior Member
Junior Member
I added a chrome paper element air breather from "mr.gasket" the filters are a stock part you can get anywhere. smile But the only reason i did it was because i channeled my truck 2.5" so the hood would not close with the stock oil bath on it. :mad: oh well u can't have everything i guess.
*under construction* 1962 Chev truck: Bagged & bodydropped, shaved, custom made clear tailights & roll pan, custom made aluminum parts.
http://www.geocities.com/philswebsite2003/
#6899 10/14/2002 1:20 AM
Back in the early 50's I worked after school in a service station where we did those old air cleaners on 37 etc. Chev's and Pontiacs, and some of those other makes like **** or Dudge.
We just put the same oil as the crankcase in those air cleaners and never saw a problem. Sure saw some pretty hard sludge in some of those air cleaners though. Good memories! I'll stay like that with my 46, 235 that is in a 2 ton.
George
#6900 10/14/2002 9:37 PM
If you drive over enough rough roads you never have sludge develop in your air cleaner, cuz the oil will get sucked down the carb!
Fred
52 3600
69 C-10
#6901 10/15/2002 7:37 AM
WHo would have ever guessed that would happen Fred grin Th eoil bath system works fine if it is s restored original or sitting on a show room floor :p
