1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 25 New Guy | | New Guy Joined: Sep 2009 Posts: 25 | Can anyone tell me what max weight is on a 55 chevy 4400.
Unladen it comes in at about 7000lbs - but I am not sure what they were rated to carry, I am guessing in region of 16k ?
thanks | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | 16k is a 61-6400. what does it say on the I.D. tag? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The maximum GVW of a standard factory-equipped 1955 4400 (1st or 2nd series) was 14,000 lbs (with different tires/springs, the Max GVW ranged from 10,000-14,000 lbs). As asked above, what is listed on the ID plate?
| | | | | Joined: Sep 2009 Posts: 25 New Guy | | New Guy Joined: Sep 2009 Posts: 25 | The plate is unreadable, someone has sprayed over it.
Thanks for your help.
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | Use a aerosol can of paint remover spray over it lightly .Then use a plastic scraper and a rag to wipe it off.Works great !
| | | | | Joined: Sep 2009 Posts: 25 New Guy | | New Guy Joined: Sep 2009 Posts: 25 | will give it a go thanks. | | | | | Joined: Sep 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 32 | Riot - the GVW isn't what the truck is rated to carry but the max weight when loaded. In other words if it's rated at 14,000 GVW and weighs 7000 then you can haul 7000 -- legally anyway. | | | | | Joined: Sep 2009 Posts: 25 New Guy | | New Guy Joined: Sep 2009 Posts: 25 | | | |
