0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#689919 10/28/2010 5:08 PM
I have a 54 exterior visor that I bought years ago that was a near-NOS unit. NOS, then painted, then didn't ever get mounted. I have a question as to how the stainless strip is supposed to be affixed to the visor. Is it riveted? Does it use sheet metal screws or machine bolts? I can't tell if the stainless strip on mine has been removed and reattached when it was painted. The underside still has the original green flat paint in tact. I would be really grateful if anyone could take a couple pics of their original unit and email them to me. [email protected] Thanks in advance!
1956 GMC 100 NAPCO Deluxe
1955.1 Chevy 3600 NAPCO
1954 Chevy 3600 NAPCO
Is this a Fulton visor? If so, you can take it apart, usually with a screwdriver, to see inside.
Question #2, Do you also have the cowl mounting bracket?,or, is this the "ballcap" style visor?
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
This is the correct dealer option GM visor. I'm not sure who made them for GM. It's the 54/55 1st series specific visor. It has a cast chromed center mount that is bolted to the center of the cab above the windshield, and then the sides are mounted to the drip rails at the front of the doors.
Check in the gallery, I know there are some photos of others that have that same visor, then shoot them a PM.
1953 Chevy Two-Ton
thanks for the suggestion, but I really don't have time to go through the gallery at this time... Anyone got an answer to this question for me? Sure would appreciate it! Thanks a bunch!
You can look at Joe Mendola's '54 or Wally54,in the Gallery, both have visors that I think you might be looking at.
1953 Chevy Two-Ton
Sent you a pm with some pictures.
