4 members (68ironhead, Hanks custodian, Gray_Ghost, Ponchogl), 51 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#68988 11/21/2006 11:20 PM
Junior Member
Junior Member
Can anyone tell me weather the positive or negeiive side of the coil goes to the distributor?
Those who fail to plan, plan to fail....
#68989 11/21/2006 11:28 PM
If its a negative ground system, which most rigs are, the negative (-) goes to the distributor . The positive side is powered (+).
Stuart
#68990 11/21/2006 11:31 PM
Junior Member
Junior Member
Thanks,Stuart, I just was'nt sure and did'nt know what would be the repercusion if I fouled it up.
#68991 11/21/2006 11:32 PM
A negative ground electrical system will have the hot wire from the ignition hooked up to the positive (+) side of the coil, with the negative side (-) to the distributor. Your truck (57 Chevy)should be a negative ground. If the wires on the coil are reversed, you'll dramatically shorten the life of your points.
Just to be sure, check your battery cable that goes to the starter....it should be the + terminal. The negative terminal should go to ground. Hope this helps.
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#68992 11/21/2006 11:49 PM
Junior Member
Junior Member
Thanks,Fla54Chevy3100 YES it does help me a great deal without all of your knowledge I'd burn down the Truck!! Thanks again, Ed
