2 members (RLB, qside), 55 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#689810 10/28/2010 4:02 AM
Ok people, according to my factory assembly manual, the exhaust pipe hanger for my 50 3800 has a 90 degree angle, and also has twist. Is this correct or is the manual misleading me? Anyone know of where I can find one, other than having one made? Thanks in advance...Clint
Are you talking about the muffler bracket or the tail pipe support?
Those are the only two supports on the exhaust system and both would be pretty easy to duplicate using the examples in the Factory Assembly Manual.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
It would be the tail pipe support.
Is this what you're looking for?
Similar, however with a 90 degree bend where it bolts to the frame, and has a twist.
