2 members (RLB, qside),
55
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | Ok people, according to my factory assembly manual, the exhaust pipe hanger for my 50 3800 has a 90 degree angle, and also has twist. Is this correct or is the manual misleading me? Anyone know of where I can find one, other than having one made? Thanks in advance...Clint | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Are you talking about the muffler bracket or the tail pipe support? Those are the only two supports on the exhaust system and both would be pretty easy to duplicate using the examples in the Factory Assembly Manual. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | It would be the tail pipe support. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Is this what you're looking for? | | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | Similar, however with a 90 degree bend where it bolts to the frame, and has a twist. | | |
