| | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Can someone point me to where I can get the correct hood emblems for my '65 1 ton?
Tnaks, John
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | I do not think the '65 had them on the hood.....pretty sure. They were on the fender, about 10-12" from the top. Rectangle style. Red background, silver lettering. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Actually the '65 had the Emblem on the small independant sheet metal piece right above the fender, between the hood and the doors, rectangle as mentioned, altho longer than the '66 rectangle Emblem.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | A "10" is the emblem for half ton, I am looing for the one ton side emblem. I believe its a "30" and slightly different, but I can't find one. John http://s783.photobucket.com/home/johntsmith1056
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | John,
I was just using that for the location and type, not the series. You are right, the 30 is for a 1-Ton. Your best bet is checking with some older Truck Salvage Yards. A yard in a dry or very dry climate would be your best bet. Searching for them and contacting them will take some time.
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | there is a set on e-bay right now | | |
