2 members (Stewart2, Hanks custodian), 96 guests, and 8 robots.
Topics128,014
Posts1,055,324
Members48,419
Hello. Over the weekend I noticed that my 63 c10 is starting to make a clanking noise under acceleration. drive train is sbc305 and th350. on several drives I have noticed this noise at different rpms and gears. only happens while in gear not while reving in park. noise will stop if i take my foot off the pedal and coast. is there something wrong with my transmission? fluid level is good. it is shifting fine. im lost here but would like to correct this problem before it causes any damage.
so:
1. clanking/slapping sound while accelerating in gear.
2. the rmp range and gear where noise present will vary.
3. problem not present in park revving motor.
4. problem stops while driving as soon as take foot off gas.
noise sounds like in the drive train hitting. gets faster with faster acceleration, as in when it begins there is a range where its heard and accelerating or decelerating in that range will make the clanking faster or slower. but once certian RPM is hit noise stops. this is driving me crazy. thanks in advance for any help
Is it possible that your motor mounts are shot and the problem occurs while using a lot of torque?
1951 1 Ton Completed
Check the universal joints, the pinion bearing in the rear end, and if it's a 2-piece driverline, check the carrier bearing between the two parts of the driveshaft. I'm betting on the carrier bearing, if it's got one!
Troy Destroy,
If you have a friend to help you, you can do a pretty simple visual exam. With the parking brake applied, have your friend lay down near the rig so he can see the drive train from front to back. At an idle, go from drive to reverse in a alternating fashion. Sometimes it's possible to see a center bearing flopping around, or a u-joint doing a death dance.
Welcome back HRL. smile
Stuart
hotrod: its a one piece drive shaft.
thanks for the suggestions guys. i'll start with the ujoints.
check and see if you have a bolt that may have come lose and just might be caught in and around the fly-wheel cover..........
Redryder pix
My Hotrod
good idea Fred. i'll check that first
one other thing. i was unable to reproduce the problem while going in reverse...
This could also be coming from the differential. Sometimes they are quiet while coasting or under moderate power but will while or make noise under heavy load. If so, there is a lash adjustment, and the bearings may need be checked.
I would vote for a bad carrier bearing. Will make a bumping sound when under acceleration or deceleration but disappear altogether when maintaining speed not under a load.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
loose torque converter bolt(s)?
Another quality post.
Real Trucks Rattle
tell us the good news.........
Redryder pix
My Hotrod
well checking the trans fluid to make sure it wasnt burnt up i realized it was a little low. topped her off and the problem went away. surprised being 1/2 qt low would cause that. alls better now
never heard of that before but glad you found the problem.. those are the best deals... grin
Redryder pix
My Hotrod
