5 members (HandyAndy, Otto Skorzeny, Hush, Maybellene, klhansen), 82 guests, and 2 robots.
Topics128,092
Posts1,056,040
Members48,433
#678 02/10/2002 5:00 AM
[img]C:\WINDOWS.000\Desktop\MVC-003F.JPG[/img]
I dont know if this picture posting is going to work but if it does. The one on the right is my stock 4sp. Transmission and the one on the left is my saginaw. Can you see the difference in bolt holes? because the bottom left one on the saginaw doesnt line up to the bellhousing. Thanks, Mike
#679 02/10/2002 5:04 PM
Joy Offline
Mike send me the pictures and I will post for you. So you can get an answer to your question!! wink
#680 02/11/2002 12:06 AM
Don't know what you've got here, but I was thinking the later sag car trans would go right into old trucks till 67 or so and then they had bigger bearing housing on front. The bolt pattern stayed the same tho. Sure you got a sag for Chev? Maybe they made some x-ler or others? Wouldn't think any GM would have diff pattern either. Any thought on redrilling for new ear? Have heard of some doing this, sounds hard to me! PS, some old F-trucks had b/house with a narrow gap for bolt on right side, is that what you have? Their housings had the narrow and the wide spacing depending on what trans went in truck.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#681 02/11/2002 2:55 AM
yes, im sure its a saginaw from a chevy. I thought of drilling the ear. but dont know if i would want to do that or not.Thanks,
Mike
#682 02/11/2002 11:16 AM
Joy Offline
#683 02/11/2002 4:32 PM
Hard to believe there's a difference. Still think it's for a diff brand! :p Not F*** as not narrow enough. AMC?
Was wondering if that rope was on it to keep it from running away? grin :p
G.L. Grumpy's
Old Iron Ranch
#684 02/11/2002 4:38 PM
I just noticed after looking again that the bearing retainer (part for t-out bearing to slide on) looks much bigger on sag than 4spd and it won't go into your orig b/house by anout the 3/8" of it's thickness. Did you find that a problem? Chevy went to bigger hole in bellhouse after 68 and these trans' won't fit earlier b/house. I was thinking the cars carried on the smaller one and if used from car will still work in old truck b/house. Is this trans from a truck? Didn't think they had small 4spd in trucks, how to shift? Think you need older trans to work for you. Lots of the cheap basic cars of 70's and 80's have these in them.
G.L. Grumpy's
Old Iron Ranch
#685 02/11/2002 4:54 PM
Anonymous
Unregistered
Anonymous
Unregistered
Its NOT a GM box thats for sure. My bet is also AMC or mopar. It dont even look like a sag to me were the counter shaft goes in.. It dont matter as GL says it wont work anyway time to get rid of it and get the right box.Show a side view and we will tell you what its for. No #'s on the box..One thing for sure you got more than just a bolt problem.
#686 02/11/2002 10:57 PM
Thanks for the information. The Transmission is from a 68 camaro. I will get the number off the side tonight.
Mike
#687 02/11/2002 11:48 PM
Here is a few pics of a genuine Saginaw 4spd in my barn. You be the judge if its the same as Bucks tranny
[img]http://pstr-m01.ygpweb.aol.com/data/00D/10/A5/76/53/a2TowIyTSavnzA3i6uzRBHTb7mAVZmK-0180.jpg[/img]
[img]http://pstr-m01.ygpweb.aol.com/data/008/3D/30/E2/8A/QaAVeic6l-CP1GNnYRO9vhOoWvOTaZnO0180.jpg[/img]
#688 02/12/2002 1:13 AM
Maybe its just me but if u put a rope on Tony's it could pass for Buck's. grin
Buzz'n Half Dozen
#689 02/12/2002 2:17 AM
hello buckonine, what truck did the older tranny come from? year? it looks like the one in my 48 gmc 3/4 ton. good luck.
our garage is a non-profit organization
#690 02/12/2002 3:17 AM
My transmission is from a 48 GMC 3/4 ton . That true saginaw looks idenical to mine. Thanks for all the information,
Mike
#691 02/12/2002 11:43 AM
I had a pile of Saginaw trannys.Some from the 70's. Everyone had the same diameter front bearing retainer, about 4-1/4 inches. Same as the hole in the older truck bellhousings,which are supposed to be the same from 48 on up.The bigger hole in the bellhousing applies to 68 and newer 4 spd trucks.I believe the trucks with 3 spd Saginaws still have the smaller opening.Looks like Bucks bellhousing may be the problem here.Perhaps GMC's are different, but a 235 housing will bolt up.
