2 members (52Carl, Gdads51),
37
Mod | | | Forums66 Topics128,180 Posts1,057,161 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I have a 66 Burb that came from the Sacramento area of California.
It is original and rather good condition. It was all white from the factory, yet has "Spec" on the paint code.
There were round Decals on the doors, so I assume that maybe they were put on from the factory. When I pulled the gas tank, it had a tag on it from the Chevy garage at Ft. Hood, up near there.
On the passenger side of the windshield on the inside, is a sticker that has me wondering, it reads:
Department of (some numbers) Consumer Affairs Approved no - system
I'm curious if anyone from up that way, may have some idea of what this may have been for? The round decals on the doors are gone, but you can sort of see the image. Unfortunately, I don't have a place to post them for you to see them.
Thank you
Last edited by Woogeroo; 10/23/2010 8:24 PM. Reason: tweaked topic/hope for more responses
| | | | | Joined: Aug 2010 Posts: 66 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 66 | That was an exemption sticker for smog inspection. Things like cars that came equipted with dual carbs were exempt also.I think that was in the early '70's. Were the decals on the outside of the doors?
- Doug | | | | | Joined: Mar 2007 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 64 | CA implemented the first emission control laws beginning in 1966. I have a 66 Rambler which sold new in CA and has an air injection pump on it. There was a requirement beginning in 1966 to install emission control devices which included crankcase ventilation systems and the carb had to be calibrated for emissions I think. I'm not sure about the carb, but there was a requirement for compliance sticker under the hood when the emissions mods were made. I think cars and light trucks imported into California had to conform for a few years. Now they don't since Federal standards have become stricter anyway. So that sticker on your windshield could have stated that the truck has beem modified to conform or that it had been exempted for some reason like 60 Anglia said. Joe | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Yes, the Decals were on the outside of the doors like a comercial vehicle would have. They were about 18" in Dia.
The Burb has a 292 with a 4 speed, and it also has the smog pump and all the goodies still on it. I figure I may as well leave it on, not like I plan to race it or any thing. I would have to double check, but I believe it lists the smog equipment on the build sheet in the glove box.
It seems kind of strange that it has the "Spec" on the paint tag, since it is all white, unless it was military or a fleet vehicle.
Thanks again for the help guys. | | | | | Joined: Aug 2010 Posts: 66 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 66 | It could have been a California State vehicle, or been owned by a city.
- Doug | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | It is possible that that the sticker in the window actually says NOX approved. During the early, retro-fitting years of smog devices many vehicles had to be fitted with system that decreased nitrous oxide (NOX) emissions. Seems like it had something to do with limiting ignition advance. I do remember that unlike the PCV systems, the NOX systems decreased performance.
Chuck | | |
