9 members (Hotrod Lincoln, Mike B, Chev4t6, cmayna, Chip O, Guitplayer, KCMongo, Wayne67vert, oldieoldie),
70
Mod | | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68875 11/20/2006 3:06 AM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Who can i hook up with that can tell me about this mod? I have searched here and on inliners with no joy. My questions are 1) How do you determine how much of the skirt to cut off. (I read somewhere that you had to cut them off) 2) which of the two choices ride higher in the cylinder? (compression) I maean which pistion has the higher wrist pin height? 3)What does this raise the compression ratio to with a stock height 250 head? 4) Do the pistons need to be releif cut to clear the valves? Thanks you guys Have a good evening. Slider
Jesus is Love! Never forget the Veteran. AND God bless Amercia!
#68876 11/20/2006 3:19 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Higher wrist pin height gives lower compression, not higher compression. Maybe you need to buy Leo Santucci's book on hopping up Chevy sixes. | | |
#68877 11/20/2006 5:26 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy sliderinwa, The 250 has a 3 7/8" bore like the 283 and 307, but it has a 3.53" stroke, the 283 has a 3" stroke and the 307 has a 3.250" stroke so niether piston would be appropriate, hope that helps. | | |
#68878 11/20/2006 5:50 AM | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | The 307 piston has exactly the same size, weight, wrist pin diameter and compression height as the 250 piston. The only difference is that the 307 is a flattop, not dished, and raises the compression. I've built 3 250 engines using them, and they work great. They're a direct swap, with NO modifications necessary. Jerry
#68879 11/20/2006 2:51 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | HRL - good to see you back! Your knowledge base was missed. | | |
#68880 11/21/2006 3:58 AM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Hot rod Lincoln. Thanks a bunch. I will buy the book as well. Please bare with me on these questions. I have the need to know, and if i can`t find it in the achrives i then ask. You fella`s are the best.
#68881 11/21/2006 4:34 AM | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Hey,, cut Slider some husk.. he's from BENTON City by golly!! :p
#68882 11/21/2006 9:45 PM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Yeah, and we ain`t got any dad-burn red lights either! I love it here. Dry and hot part of Washington State. We`ll not to hot in winter, but dry. I know the sbc rods are off set, and i don`t think i need any thing but press fit wrist pins. I will try and find out how much the compression is increased by going to the 283/307 pistons.After having worked on Chev v8, vw`s and Harley engines all my life i am totall excited about the inline six. Way cool to me. something new to learn. i guess is the word.Have a fun day. I have order the chevrolet inline six power building manual .
#68883 11/22/2006 2:52 AM | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | I don't recall the exact numbers, but the last 250 I built got 307 pistons, AND a .050" head mill, and it still runs on regular gas, with a stock cam, and doesn't detonate. I figure that's about the ragged edge of too much, though! Jerry
Edit: The 250 rod length is WAY different than a V-8, so you'll need to use the 6-cylinder rods, not the smallblock V-8's. Jerry
#68884 11/22/2006 6:08 AM | Joined: Oct 2005 Posts: 7 Junior Member | | Junior Member Joined: Oct 2005 Posts: 7 | The way I understand it, the 307 is the piston to use because almost same as 250 except flat top and just a few thousands short of deck height. The 283 is not used because it has a shorter distance from pin to top of piston, therefore would be too short in cyl..
Am I correct?
Stock 250 piston is dished about .085" also.
What cam for street driving? Stock or a RV grind?
Just my Thoughts, Walt
#68885 11/22/2006 9:55 PM | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | You've got the picture, Walt! The actual compression pressure will be highest with the stock cam, as it closes the intake valve sooner on the compression stroke and there's more volume to compress. An RV cam usually makes only a slight increase in duration, but it has a higher lift to allow for longer useful open time of the valves. RV cams generally develop lots more low-end torque than stock cams, without making much of a change in the top-end horsepower. If you want a stump-pulling off road engine, or you're hauling heavy loads on the highway, the RV cam is the way to go. Jerry
