1 members (baldeagle),
36
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Hello,
I am getting ready to put my refreshed 235 into my 1946 Chevy Stylemaster Sedan. The originally had a 216. I ordered a set of motor mounts off ebay for a 235. What arrived was far different from what "fell off my motor." The old ones are so badly mangled I cant even figure out how they go back into the engine compartment. They were covered in grease when I removed the engine and fell off sometime while I was ripping the old motor out. Does anyone have any pictures of what the correct motor mounts for this swap look like, where I can find a set, and how i reinstall them.
thanks,
Dan
1946 Chevy Stylemaster Sedan - 216 6 Cylinder 1971 Chevelle SS 1995 Monte Carlo Z34 2005 Corvette Z51
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Give these folks a call. http://www.oldchevytrucks.com/Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Dan, For a car, you might want to try Chevs of the Fotries. i assume that both front and rear mounts are needed . Is the 235 front plate being used? it may need to be drilled to accept the 1946 216 mounts. Also, is the 216 bellhousing being used? I did not see an illustration in the Shop Manual , but there are instructions. Hoyt
| | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | I am drilling holes to utilize the 216 mounts. The bell housing I have is supposedly from a 216, but I can always swap mine on if its an issue.
DG
