8 members (NJC, cmayna, Hotrod Lincoln, lumbersawyer, JW51, 3B, cshades, 1 invisible), 100 guests, and 6 robots.
Topics128,064
Posts1,055,860
Members48,428
#68865 11/20/2006 1:44 AM
Went to move my truck today, and the clutch would not release. I tried to adjust it, but there was no more positive adjustment left. I ended up starting it in reverse (not reccomended) and then started it in 2nd to move it across the street. To stop I simply killed the ignition. The clutch finally freed up and the truck could be driven {normally}.
What happened? The throw out bearing travels almost 3/4 of an inch before it contacts the the pressure plate fingers. Could the clutch disc have rusted to the flywheel?
I don't want to spend any money right now to fix the clutch as I am getting ready to do the engine, transmission, and rear end conversion, but I would like to keep the truck driveable till I collect all the parts I will need.
Any insight or suggestions?
#68866 11/20/2006 1:48 AM
never seen that problem before,, how long had it been sitting? had shifter to hang up between gears and you could rock one to get them out.. but..
Redryder pix
My Hotrod
#68867 11/20/2006 3:08 AM
Clutch discs do rust to the flywheel, but it usually takes weeks of sitting.
#68868 11/20/2006 11:45 PM
Riding in the Passing Lane
Sometimes a spring comes out of the clutch disc & lodges in the pressure plate causing the clutch to not release. Pull the lower flywheel cover & see if you can see anything or if a part is lyeing in it.
1972 Chevy c10 Cheyenne Super
#68869 11/21/2006 8:11 AM
I'll check that out tomorrow. I didn't here anything ratteling around in there, but that is a good place to start.
