| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68865 11/20/2006 1:44 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Went to move my truck today, and the clutch would not release. I tried to adjust it, but there was no more positive adjustment left. I ended up starting it in reverse (not reccomended) and then started it in 2nd to move it across the street. To stop I simply killed the ignition. The clutch finally freed up and the truck could be driven {normally}.
What happened? The throw out bearing travels almost 3/4 of an inch before it contacts the the pressure plate fingers. Could the clutch disc have rusted to the flywheel?
I don't want to spend any money right now to fix the clutch as I am getting ready to do the engine, transmission, and rear end conversion, but I would like to keep the truck driveable till I collect all the parts I will need.
Any insight or suggestions? | | |
#68866 11/20/2006 1:48 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | never seen that problem before,, how long had it been sitting? had shifter to hang up between gears and you could rock one to get them out.. but.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#68867 11/20/2006 3:08 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Clutch discs do rust to the flywheel, but it usually takes weeks of sitting. | | |
#68868 11/20/2006 11:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sometimes a spring comes out of the clutch disc & lodges in the pressure plate causing the clutch to not release. Pull the lower flywheel cover & see if you can see anything or if a part is lyeing in it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#68869 11/21/2006 8:11 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | I'll check that out tomorrow. I didn't here anything ratteling around in there, but that is a good place to start. | | |
