1 members (baldeagle), 73 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#688630 10/23/2010 6:26 PM
Hello,
I am getting ready to put my refreshed 235 into my 1946 Chevy Stylemaster Sedan. The originally had a 216. I ordered a set of motor mounts off ebay for a 235. What arrived was far different from what "fell off my motor." The old ones are so badly mangled I cant even figure out how they go back into the engine compartment. They were covered in grease when I removed the engine and fell off sometime while I was ripping the old motor out. Does anyone have any pictures of what the correct motor mounts for this swap look like, where I can find a set, and how i reinstall them.
thanks,
Dan
1946 Chevy Stylemaster Sedan - 216 6 Cylinder
1971 Chevelle SS
1995 Monte Carlo Z34
2005 Corvette Z51
Give these folks a call.
http://www.oldchevytrucks.com/
Harold
Harold
Harold46 #688655 10/23/2010 8:43 PM
Dan,
For a car, you might want to try Chevs of the Fotries. i assume that both front and rear mounts are needed . Is the 235 front plate being used? it may need to be drilled to accept the 1946 216 mounts. Also, is the 216 bellhousing being used?
I did not see an illustration in the Shop Manual , but there are instructions.
Hoyt
hoyt #688714 10/24/2010 1:12 AM
I am drilling holes to utilize the 216 mounts. The bell housing I have is supposedly from a 216, but I can always swap mine on if its an issue.
DG
1971 Chevelle SS
2005 Corvette Z51
