1 members (tclederman),
94
Mod | | | Forums66 Topics128,181 Posts1,057,185 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | I have a 1943 Chevy Fire Truck with a 216 Engine. I need a new water pump. I have removed the old one and found that it has a 3/4" pulley. I'm having a super hard time finding one to replace the old. I have found one that is out of stock with no known arrival date. I can also find lots of them with the standard 5/8 pulley. Any help on what I might can do to resolve my problem? The pulley is attached to the water pump so I cant change it? | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Can you find someone who can rebuild your pump? Sometimes that's the only way to deal with super-scarce parts. What sort of problem does your existing pump have? If it's leaking, there's a mechanical seal that could be changed and the old pump could be reinstalled. Water pumps and fuel pumps used to be rebuilt pretty routinely by repair shops. Edit: A quick web search turned up these guys- - - -give them a call or an email. http://www.kelloggautomotive.com/about.html Jerry
| | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | Its not leaking that I know of. I bought this truck that already been restored but the guy I bought from had passed away in 2007 so the truck just sat in a airplane hanger and hasnt been run since then. I think that it just rusted and froze up? I have removed it but I cant even remove the 2 screws from the backside to get inside it to see if maybe I can free it up and clean to reuse. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Try immersing it in a container of Diesel fuel for a while, even a few days. It won't hurt it to do that, and you might save yourself the cost of a rebuild job. Jerry
| | | | | Joined: Oct 2010 Posts: 39 New Guy | | New Guy Joined: Oct 2010 Posts: 39 | | | |
