| | | Forums66 Topics128,034 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | Hi all,
My old 216 finally bought the farm(she blew up). I am going to swap it out for a mid seventies 250. Any ideas on short cuts or problem areas. It is going in a 1948 2 ton.
JMH | | | | | Joined: Oct 2010 Posts: 1 New Guy | | New Guy Joined: Oct 2010 Posts: 1 | Hi JMH Im tring to do the same thing in a 52. Someone have any info. Thanks Bob | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | There is a good tech tip on this site about the bell housing you will need for the swap. You can also search these forums as this swap has been discussed, and done a lot. Good luck!!
Professional Novice
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Probably no shortcuts, obviously you'll need custom motor mounts. The early V8 bell housing works on a 54 crossmember. Water pump/fan will be tight fit but will work, and be a little low on the radiator. Someone makes custom motor mounts, do a search, topic has been well covered. I'm putting a 250 in my 54 3100. | | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | Thanks everyone. The swap is forthcoming. I think I have the details worked out. See my latest post in the Big Bolts forum.
Thanks JMH | | |
