1 members (78buckshot), 38 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#688025 10/21/2010 12:01 PM
I searched the archives with no success but I know I've seen it once, but can someone tell me what is the difference between 55-56 and 57 front fenders. I'm looking for clean rust free originals for a 57 and all I find are 55-56, can they be modified to fit ? Frank.
55-56 fenders will fit fine, the difference is in the grille area. you can use them as-is if you are willing to use the 55-56 eggcrate grille. if you must have 57 grille then you need 57 fenders. there is a flat-spot/notch and hole on the 57's to accept the different grille.
i know this, because I have the opposite problem as you, as i describe in this thread:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=687143#Post687143
Do you think 55-56 fenders could be modified to fit the 57 grille ? Could that section be cut from the "old" 57 fender and grafted to a 55-56 fender ? Frank.
yes - I absolutely believe that is readily achievable - it would not be too large of a patch, either.
I think it'd be possible without actual grafting, just need to drill the earlier fenders for the grill mount bolts and do some creative fudging - look at your 57 fenders, there's only one bolt hole on each fender at the side of the grill opening, those holes and the flat spots won't be on the earlier ones
