1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
Some where in the past I've seen instructions and warnings about what to do and not to do about greasing,servicing and maintinance of closed drive train .Any help on locating this info. will be appreciated ---I've gone thru search and can't locate.Thanks
ODSS Lawman
ODSS Lawman
Check the fluid levels in both the rearend and the transmission. Finally, put fluid in the front u-joint. This items is often missed and leads to many u-joint failures.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Thank you ,will comply,I've remembered that somewhere it says ONLY fill at the speedometer input point.Does that ring a bell or am I imagining that up? Thanks again --looks like you've got alot of fun underway.
My 38 Chevy 1/2 ton has a fill hole for the u-joint where the battery ground connects to tranny. Hope that helps. Good luck!
I'm glad someone brought this up. My U-joint has a grease fitting... what's up with that? Can you use grease in there or did someone just give up trying to keep it full and decided at least grease is better than nothing?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
What tranny are you using? My SM420 has a plug on the back on top of the U-joint housing which you remove and fill with tranny oil to lube the U-joint.
Craig
Mine is the SM420 also and I think the PO either got tired of filling it because of leaks or he lost the cap and just stuck a grease fitting in the hole.
I'm afraid mine isn't in the best of condition sealing-wise and was curious if greasing these things is some kind of "old school work around" for leaky u-joints.
Woody
Door Art Collection
I can't imagine grease staying adhered to the u joint once it has spun around fast a couple times. Now if the U-joint had zerk fittings on it like a modern U-joint then that would be a cat's meow.
Craig
Thanks, that answers my question. I'll find a plug with the correct threads and use it.
Woody
Door Art Collection
I have read that the "grease"-fitting near the top of an SM420 torque-tube housing was used at the factory to shoot in transmission lubricant to make sure enough fluid was in the u-joint housing. This could be a myth.
