4 members (Nick in Manitou, baldeagle, Lightholder's Dad, Hotrod Lincoln), 50 guests, and 2 robots.
Topics128,014
Posts1,055,333
Members48,419
#68801 11/18/2006 10:32 PM
Out of courisoty mostly can a 700r4 (early non computer controlled) transmission be mounted on the 230,250,292 inliners/Thanks in advance
Jesus is Love! Never forget the Veteran.
AND God bless Amercia!
#68802 11/18/2006 10:42 PM
Yes. Well yes, if its a Chevy V-8 type.
I don't remember for sure, but I think the 700r4 was available in two types and the other would not work on your 250.
The 230, 250, 292 have the Chevy V-8 bellhousing pattern.
#68803 11/18/2006 10:49 PM
Riding in the Passing Lane
It fit,s the engines & uses the same drive shaft yoke as the other trans. The throttle cable is critical. It must operate & be adjusted correctly.
1972 Chevy c10 Cheyenne Super
#68804 11/19/2006 2:54 AM
Thanks and Yes the throttle cable must be adjusted correctly at wot. (wide open throttle) I have used these 700r4s behind sbc and don`t see why they would not be a great idea fir the 250 six.
#68805 11/19/2006 3:01 PM
#68806 11/19/2006 5:29 PM
I have got a 95 Caprice Cop Car with a LT-1 and 700R and disc posi rearend that I want to put in a a 53 five window. Any slick tricks? Would also like opinion on best front end (Mustand II) to use.
Thxs
#68807 11/19/2006 5:54 PM
Hea Chuck the truck, i just found your site. More questions answered. Thank you for putting it up. Slider
