| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 6 New Guy | | New Guy Joined: May 2009 Posts: 6 | I searched the archives with no success but I know I've seen it once, but can someone tell me what is the difference between 55-56 and 57 front fenders. I'm looking for clean rust free originals for a 57 and all I find are 55-56, can they be modified to fit ? Frank. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | 55-56 fenders will fit fine, the difference is in the grille area. you can use them as-is if you are willing to use the 55-56 eggcrate grille. if you must have 57 grille then you need 57 fenders. there is a flat-spot/notch and hole on the 57's to accept the different grille. i know this, because I have the opposite problem as you, as i describe in this thread: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=687143#Post687143
| | | | | Joined: May 2009 Posts: 6 New Guy | | New Guy Joined: May 2009 Posts: 6 | Do you think 55-56 fenders could be modified to fit the 57 grille ? Could that section be cut from the "old" 57 fender and grafted to a 55-56 fender ? Frank. | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | yes - I absolutely believe that is readily achievable - it would not be too large of a patch, either.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I think it'd be possible without actual grafting, just need to drill the earlier fenders for the grill mount bolts and do some creative fudging - look at your 57 fenders, there's only one bolt hole on each fender at the side of the grill opening, those holes and the flat spots won't be on the earlier ones
Bill | | |
