2 members (dt235sd, JW51), 204 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#687777 10/20/2010 5:16 PM
I am installing a/c in my 63 chevy 1/2 ton soon and have a question about altenators. It has a 40 amp externally regulated alt. and im thinking about buying a 80 or 100 amp alt for it. I have a dual electric fan set up and maybe a third pusher fan for the condensor, just depends on the high side pressure for the third fan. Should I switch to internally regulated or just buy the external 100 amp? I've heard its an easy switch, not really sure if Im going the right direction with the externally regulated alt. thanks for the input. I dont really care which way I go just want the best solution for my trucks electrical system with the extra load
Riding in the Passing Lane
You will need an internal regulated alt for that kind of amps.
1972 Chevy c10 Cheyenne Super
It is also my understanding you'll need an internally regulated alternator to obtain those amp levels. The following site has a ton of electrical information should you be interested:
http://www.madelectrical.com/electricaltech/howitworks.shtml
I haven't done any recent research, but don't believe external regulators were ever upgraded, and the old contact points just don't have the same reliability as modern electronics.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
I've used this alternator 100 AMP ,1 wire, PN SUM-811001 .From Summit Racing is where I bought it.You should only need two fans at the most even with A/C.I use PERMA COOL PN19115 .They are 16in FANS with metal blades.The plastic blades do break easy.The fans CFM is 2950 per fan with a 9.8 AMP.Ive ran this combination many years hope this helps.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
