2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
#68760 11/17/2006 5:35 AM
Junior Member
Junior Member
Hi folks,
My stock '49 3100 is having shifting issues.
Sporadically the transmission will not come out of gear and sticking has happened in all forward gears. To get the transmission to shift again, I have to kill the engine, then move the transmission control assembly lever on the steering column under the hood of the stuck gear. Shifting then works great until it happens again, which can be in fifty feet or twenty miles. Any ideas of the issue and more importantly, the fix? All help is greatly appreciated!!!
#68761 11/18/2006 12:06 AM
DW Offline
Hi Larry,
I had the same problem with my 49 3100 spd. It happened "occassionally" but occurred more frequently as time went on. I could sometimes fix it the same way you do (trying not to get grease on my work shirt!), but sometimes it was "stuck" further down the shift linkage. Pulling up on the linkage from the transmission sometimes worked, but I've driven home stuck in third gear twice!
After thinking about it quite a bit, my final solution was to buy a t-5 transmission and the rear end from a 59 1/2 ton. I'm pulling the old rear end off this weekend.
Dave
#68762 11/18/2006 12:10 AM
Riding in the Passing Lane
Take the shifter box off the steering column & o-haul or get a rebuilt one.
1972 Chevy c10 Cheyenne Super
#68763 11/18/2006 1:38 AM
There is a spring inside of the shifter box.I had to replace mine years ago,it solved the problem getting hung inbetween 2nd and 3rd gear.
1951 3100 Chevrolet
