0 members (),
84
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I'm pretty sure I've read every post on this forum about oil in the rear axle.
Here's what I gathered - if its got good seals (all new now) then I'm ok with 80W90, but otherwise I should use 90wt (Pure 90 - I'm guessing its more viscous?)
The post that I read that concerned me mentioned that heavier duty trucks should use the heavier oil. Mines a 1 ton - what do the other 1-tons guys use?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I use the 80W90 in mine. The writing on the bottle leads me to believe that it is good for much heavier trucks too. | | | | | Joined: Jul 2009 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 23 | I've been selling oil for 30 years and your right truckernix, 80/90 is used in some big rigs. Most big rigs use 85/140, but small trucks and cars have been using 80/90 for many years now. I havent sold any straight 90 for at least 20 years, dont even carry it anymore. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Thanks for the advise - I filled it up with 80W90 and so far no leaks. Quite the contrast in the color of what I drained out, vs what I put in! | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | I've been using 85W-140 in all my vehicles, cars and trucks, for many years. The "W" stands for "winter", and the flow rate is measured at zero degrees, Farinheit, I believe. It just flows a little better and lubricates well at very low temps. 90 weight and similar straight viscosity oils get as gummy as molasses as the temperature drops, adding a lot of drag and not doing a very good job oif lubricating bearings. Jerry
| | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | We use 80w140 synthetic in all our rear ends. Back before synthetic multigrades, it was common for straight 90w to get so thick when the temp got to around -20° Fahrenheit that the gears slung the grease away from themselves and the gears would run dry. I have seen the the whole third member turn cherry red and of course it was ruined. | | |
