| | | Forums66 Topics128,196 Posts1,057,398 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 11 New Guy | | New Guy Joined: Aug 2010 Posts: 11 | Hey y'all,
Will the horn relay off a 57 passenger car work on a 59 truck? I just thought I'd ask before I went wading through the briars and the copper heads to get one to try.
Thanks! Layne | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | well they're both 12V and the horns should be about the same, if not identical .... might as well try
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don't see why not Layne, all it does is use a small current draw coil to make the contacts for a large current device. As Bill points out, as long as they are both 12v and the current draw is probably the same. DG
Denny G Sandwich, IL
| | | | | Joined: Aug 2010 Posts: 11 New Guy | | New Guy Joined: Aug 2010 Posts: 11 | Thanks. We'll give it a try then! | | | | | Joined: Aug 2010 Posts: 11 New Guy | | New Guy Joined: Aug 2010 Posts: 11 | For the record...Yep. Works great. The one I scavenged off a 57 wagon appears identical to my 59 truck and works perfectly. | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | Glad it worked, if needed in the future a simple 12vdc Bosch type relay would do the same and easy to come by. | | |
