9 members (Phak1, Bill Hanlon, Rusty Rod, TUTS 59, Napco Man, Cosmo, ndkid275, 2 invisible),
57
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | i have a couple of nice 57 fenders that i plan to use on my 56. they have that flat spot near the grille that the 55.2/56 fenders do not have. i guess i have a couple of choices here:
1) forget about the difference, put on my 56 grille and live with it (how noticeable will this be? i'd like to show the truck from time to time)
2) use a 57 grille (will it fit and conceal this feature of the 57 fenders?)
3) fill/cut out the fender notch and make the 57 fenders look like 56 fenders (is this feasible?)
what are the thoughts of the group?
thanks!
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you could do any of the above, but you should at least fill the holes in the middle of those flats or it will be noticeable  those flats are for the 57 grill mount bolts, the top cross pice needs them as well to mount the 57 grill Bill
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | thx Bill - i don't have those holes in the 57 fenders... someone must have filled them in the past... | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | I have seen it done here in Texas 57 fenders n 55/56 grill, done right and you can't tell. Done wrong or not at all and it IS obvious the mis match. My vote cut and fill.
Brad | | |
