2 members (BC59, Bill Hanlon),
152
Mod | | | Forums66 Topics128,088 Posts1,056,109 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | I have a 54 bed installed along with my 54 cab on a 53 frame. Yes, the hump over the rear axle has been modified (lowered and boxed). Everything fits as you can see on my truck pictures. I would like to try installing the cross sills in the original locations if possible. Would anyone with an original 54 bed be willing to give me the measurements, front to rear, of placement? How many inches to the center of the first cross sill, from the front to the center of the second, etc. I don't have any trucks around me to look at. Dan | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Since you will need bed strips (if you plan a wood bed), all the marks are right there. I would mock up the rear cross sill and measure locations for the other bolted-on sills from the holes in the strips.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello 54 dd. just measured the locations of the cross bars on my 55 first series short box. using the corresponding strip bolt heads,, from the centers,[REARMOST BOLT MEASURING FORWARD],from the first bar,, the second bar is 22 3/4 in.,,,the third bar is 26 3/4 in. from the second,, and the fourth bar [most forward] is 24 1/8 in. from the third. be careful if you locate the bars using the holes in the strips as some of the holes do not correspond to the cross bars. some of the bolts just use washers and nuts on the bottom side. hope this helps.
our garage is a non-profit organization
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Dan I'm not physically capable of measuring things right now, but I have two '54 1/2-ton beds setting here and you'd be welcome to come over and measure and photograph all you want.
I'm in the Island Center area on Bainbridge Island so its no more than 50 or so miles from anywhere that can be called Port Townsend.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | Err, Can't come over. But thanks though. I'm 9 hours south of the Arizona border. Restoring this in my garage in Alamos, Sonora. Wish I could drop by though. | | | | | Joined: Mar 2009 Posts: 58 New Guy | | New Guy Joined: Mar 2009 Posts: 58 | Gary, thanks for the measurements. I have the bed strips here so I should be able to locate the positions with your info. Thanks again for taking the time to do this.
Dan | | |
