| | | Forums66 Topics128,162 Posts1,056,933 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 62 | http://i131.photobucket.com/albums/p291/mrduckphoto/swaybar.jpgI have what appears to be a stock sway bar on my 57 Panel. However, all the parts places I've talked to don't show this and I can't find any replacement rubber as the original stuff is shot. So, anyone else have one of these and where do I find replacement rubber for it Thanks Don J  | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi Don contact Steele Rubber they have American made rubber... Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Oct 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 62 | Thanks, all ready tried them. But I did get the new rubber back door seals from them! Don J  | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the front anti-sway bar was on all TF panel and suburban bodied trucks only [should be shown in the assembly manual], no part of it is reproduced, including the rubber
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Too bad the parts do not interchange with the 3400/3500/3700 Step Vans, the bushings for the sway bars for those are still available from Moog.
Bill Burmeister | | | | | Joined: Oct 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 62 | So the next question is can I send the parts off to someone to fabricate new or do I toss the stock sway bar and go aftermarket? Don J  | | |
