| | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | I want to fabricate two “pins” for temporary use in the top two transmission to bell housing bolt holes to use for proper alignment to reattach my transmission to the bell housing. How long should they be? Thanks John
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | doesn't take much 'fabrication' or precision John, just find a couple 3 or 4" bolts the right size and cut the heads off  Bill | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | After you cut the heads off then cut a slot in the top that a flat screwdriver will fit in. Much easier to get them out!! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Someone(maybe you Tim) some time ago mentioned about using the cut off bolt to steady the trans when removing. It really worked well me more then once too. I did decide to use 6" bolts though.
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, I have posted this advice, as have several other people. Shop Manuals all state that "guide pins" should be used when installing a transmission. It took me many years (and many transmission removals/installs) before I decided to make my own "guide pins" (now I don't waste any swear words when installing an SM420). | | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | I've got a 4 speed on my '53 3/4 ton. I got two 6" carriage bolts like someone on this site told me not two weeks ago. On the left side there was enough clearance to use the whole bolt. On the Right side though I had to cut the carriage bolt only about an inch longer than the bolt (screw cap) that came out because part of the transmission protrudes out far enough behind the hole to block anything longer. This was enough though as I only screwed the carriage bolt in four threads. The longer left side gave me the stability I needed after I ran out of bolt on the right side (of course, I was removing). Good luck.
'53 Chevy 3604 Five Window Cab ('56 235)
