5 members (rfs56trk, Otto Skorzeny, FAST55, 216wny, Gdads51), 86 guests, and 1 robot.
Topics128,038
Posts1,055,585
#686433 10/15/2010 5:46 PM
I want to fabricate two “pins” for temporary use in the top two transmission to bell housing bolt holes to use for proper alignment to reattach my transmission to the bell housing. How long should they be?
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
doesn't take much 'fabrication' or precision John, just find a couple 3 or 4" bolts the right size and cut the heads off wink
After you cut the heads off then cut a slot in the top that a flat screwdriver will fit in. Much easier to get them out!!
I recently installed (three times) an SM420 that came from a big truck. I do not know if the SM420 cases had different protrusions but I had to use the alignment/mounting bolts as described in this post.
Someone(maybe you Tim) some time ago mentioned about using the cut off bolt to steady the trans when removing. It really worked well me more then once too. I did decide to use 6" bolts though.
Drew
Yes, I have posted this advice, as have several other people. Shop Manuals all state that "guide pins" should be used when installing a transmission. It took me many years (and many transmission removals/installs) before I decided to make my own "guide pins" (now I don't waste any swear words when installing an SM420).
I've got a 4 speed on my '53 3/4 ton. I got two 6" carriage bolts like someone on this site told me not two weeks ago. On the left side there was enough clearance to use the whole bolt. On the Right side though I had to cut the carriage bolt only about an inch longer than the bolt (screw cap) that came out because part of the transmission protrudes out far enough behind the hole to block anything longer. This was enough though as I only screwed the carriage bolt in four threads. The longer left side gave me the stability I needed after I ran out of bolt on the right side (of course, I was removing). Good luck.
'53 Chevy 3604 Five Window Cab ('56 235)
