2 members (52Carl, Jon G),
135
12
Mod | | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Did a dumb thing the other day. Washed my ’41 with the cowl vent open, fried the new radio mounted under the dash.
I wonder if I’m missing some kind of baffle under there. Sure seems like a great opportunity to short a lot of stuff by simply driving in the rain with the vent open.
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Sorry for your misfortune, but maybe you've saved someone else from this experience. Thanks | | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | Not sure about the Art Deco trucks, but the cowl vent on the '47-54 trucks has a drain and rubber nozzle that empties into the engine compartment. | | | | | Joined: Jan 2009 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 106 | The first time I removed the original radio from my 1954 3100 1/2 ton, I saw it had a thin fiber board cover that attached from the top of that tall speaker and went down on a 45 degree angle past the back end of the radio. It was very weathered. It looked original but I couldn't be sure. I found a thin cardboard box with a sealed surface on one side and made a new piece to replace the old one. It sheds moisture that may get in some way. The 54 also has the cowl vent drain hose down the firewall in the engine compartment.
Stovebolts are good for the heart
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | maybe you've saved someone else from this experience. Thanks Yea, like me. I don't need to cook my repro radio either. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | The deco trucks also have a drain, but it is only for the recessed track that the rubber vent cover seal/gasket sets into.
The area below the vent itself is wide open to the area behind the truck's dash.
