3 members (1955 1 Series, Gray_Ghost, Chip O), 138 guests, and 1 robot.
Topics128,191
Posts1,057,348
Members48,469
#68655 11/15/2006 2:06 PM
I just bought a 6400 2 ton with a 261. I would like to put the 261 into my 1 ton stake truck. My question is; will the 6400 radiator and engine bolt up to my 4 speed trans? Or do I just move the engine over? I'd like to use the bigger radiator if I could but am unsure if the bigger truck stuff would fit in the smaller sheet metal of the 1 ton.
My Trucks
Stuff I Collect
#68656 11/16/2006 7:07 PM
The 1 ton radiator should be able to handle the 261 without problems. The 261 flywheel and bellhousing interface is the same as the 235.
Paint & Body Shop moderator
#68657 11/16/2006 10:51 PM
What year truck is the 261?
Is your 235 in the 1955-1st the original 6v engine/flywheel?
#68658 11/16/2006 10:56 PM
Both the 1 ton and the 2 ton are 1954 models. I assume everything is original. I know the 2 ton is original and unmolested with a bunch of factory accessories. The 1 ton actually has a 1950 216 in it. I'm unsure if the transmission has also been changed. I need to get a putty knife and dig for some numbers to find out.
My Trucks
Stuff I Collect
#68659 11/17/2006 3:26 AM
Just bolt it in and go.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#68660 11/19/2006 9:34 PM
I tranplanted a 261 in my 51 half ton. The 261 I got was from a later 12 Volt heavy truck (2 ton?). I wanted to keep the stomp starter so I used the flywheel, clutch disc, and pressure plate from a 235 I got from another 1.5 ton truck (6 volt). The 12 Volt starter ring gear has more teeth and will not work correctly with a 6 volt stomp starter. I run the 6 volt starter on 12 volts and have had NO problems with it, but my pickup starts in about 1 one revolution.
I used the bell housing from the 235 I originally pulled out of the 51 after having it bored to fit the 89MM tranny input bearing housing. I also installed a radiator from a 50 Chevy 1.5 ton truck since it has one more row in the radiator (3 rows instead of 2 in the half ton radiator). Chevy trucks were not noted for having heating problems and I can run down the road 70+ mph all day in the summer (100 degrees+) and the temp gauge never gets above 180. Even around town with little air flow across the radiator it never seems to get hotter than 180.
Everything I did with the exception of boring the bell housing for a modern transmission was a bolt-in swap.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#68661 11/20/2006 7:08 PM
Thanks Racecarl, it's good to know its not that big of a deal. I'm fortunate I will be transplanting a 1954 261 into a 1954. This should make life fairly easy.
My Trucks
Stuff I Collect
